Fix StreamDock Hotkey Issues on macOS
Introduction
If your hotkeys are not working properly on macOS when using Stream Dock, you’re not alone.
This issue is usually not caused by the device itself, but by macOS system permissions or application-level restrictions.
In this guide, we’ll explain how hotkeys work on macOS and how to fix the most common issues step by step.
What Are Hotkeys on Stream Dock?
Hotkeys on Stream Dock use virtual key input (software-level simulation) rather than physical keyboard signals.
This means:
  • Commands are sent through the system as software events
  • macOS requires explicit permission to allow these actions
  • Some applications may block or ignore virtual inputs
Why macOS Hotkeys May Not Work
If your hotkeys are not responding, it is typically due to one of the following reasons:
  • Stream Dock does not have required system permissions
  • macOS is blocking virtual key input
  • The target application restricts external input
How to Fix macOS Hotkeys Not Working
Follow these steps to resolve the issue:
Step 1: Enable Accessibility Permission
  1. Open System Settings
  2. Go to Privacy & Security → Accessibility
  3. Locate Stream Dock
  4. Enable the toggle
This allows Stream Dock to control keyboard input.
Step 2: Enable Automation Permission
  1. Go to Privacy & Security → Automation
  2. Find Stream Dock
  3. Enable all related permissions
This allows Stream Dock to interact with other applications such as browsers, OBS, and more.
Important Limitations
Even after enabling permissions, hotkeys may not function in certain environments:
  • Fullscreen games
  • Applications with strict security restrictions
  • Sandboxed or protected software
These applications may block software-level key simulation.
Recommended Solution: Use Super Hotkey
If standard hotkeys do not work as expected, we recommend using:
Super Hotkey (Enhanced Mode)
Benefits include:
  • More reliable execution
  • Improved compatibility with restricted applications
  • Better performance in complex workflows
Conclusion
To ensure macOS hotkeys work properly on Stream Dock:
  • Enable Accessibility permissions
  • Enable Automation permissions
  • Be aware of application-level restrictions
  • Use Super Hotkey for advanced scenarios
By following these steps, you can significantly improve hotkey reliability and performance.
