Fix StreamDock Connection and Recognition Issues
If your StreamDock is not connecting or your computer does not recognize the device, don’t worry—this issue is often caused by software versions, USB connection problems, firmware compatibility, or power delivery issues.
This guide walks through proven solutions to get your device working again.
1. Check Your StreamDock Software Version
An outdated software version can cause connection or recognition problems.
Steps:
  1. Open StreamDock
  2. Go to Settings → General
  3. Click Check for Update
Make sure you are using the latest version of StreamDock software.
If needed, download the latest version from the MiraBox official website.
2. Check Your USB Cable
A faulty or low-quality cable is one of the most common reasons a StreamDock is not recognized.
Make sure:
  • The USB cable is securely connected
  • You are using a data cable, not a charge-only cable
  • The cable is not damaged or too long
  • Try another high-quality USB cable if possible
3. Try a Different USB Port
Sometimes the problem is the USB port rather than the device.
Recommended:
  • Use a different port
  • Use a USB 3.0 port
  • Connect directly to your computer
Avoid:
  • USB hubs
  • Docking stations
  • Monitor USB ports
Insufficient power delivery can prevent your StreamDock from being detected properly.
4. Check AMD Compatibility Issues
Some Windows computers with AMD processors may experience device recognition problems.
Fix:
Test the device on another computer first:
  • Mac
  • Intel Windows PC
If recognized:
  1. Download the latest standalone firmware updater
  2. Update firmware
  3. Reconnect the device to your original computer
This often resolves AMD-related recognition issues.
5. Check Device Logs
If the issue persists, collect diagnostic logs.
Path:
StreamDock → Settings → General → Open Application Folder → Logs
You can also use USBTreeView to verify whether the system detects the device.
Useful screenshots:
  • Device not appearing after connection
  • USB driver errors
  • Device briefly recognized, then disappears
6. Contact Support for Replacement
If none of the above resolves the issue, contact support and provide:
  • Order number
  • Shipping address
We can arrange a free replacement with an upgraded device if necessary.
Optional Remote Engineering Support
For advanced troubleshooting, we can arrange Zoom remote support with our engineering team.
Additional compensation may be provided for users assisting with remote diagnostics.
Frequently Asked Questions
Why is my StreamDock not recognized?
Common reasons include:
  • Outdated software
  • Faulty USB cable
  • Insufficient USB power
  • AMD compatibility issues
  • Firmware requiring updates
Why does my StreamDock connect and disconnect repeatedly?
This is often caused by:
  • Unstable USB power
  • Bad cable
  • Faulty hub or docking station
  • Firmware compatibility issues
Can AMD CPUs cause StreamDock detection issues?
In some cases, yes. Updating firmware through another computer often resolves the issue.
