How to Switch Lighting Effects
After connecting the keyboard to the Web UI, or using Keyboard Mode in the Stream Dock software, open the Light Effect tab. You can customize the keyboard lighting using the following options:
1. Light Effect Mode
Select the lighting effect you want to use, such as Static, Gradient, Breathing, Wave, Ripple, and other available effects.
2. Effect Speed
Adjust the animation speed of the selected lighting effect. Some static effects may not use this setting.
3. Brightness
Adjust the overall brightness of the keyboard lighting.
4. Custom Color Switch
Click the switch to enable Custom Color. When the switch turns green, custom color adjustment is enabled.
5. Custom Color
After enabling Custom Color, use this area to select the lighting color you want. You can choose a preset color or manually adjust the color.
Quick Setup:
Choose a lighting effect → Adjust the speed → Set the brightness → Enable Custom Color → Select your preferred color.
