Stream Dock Battery
How to Use Battery Plugin with Stream Dock
Tired of fumbling through 4 different apps just to check if your gaming controller has enough juice for your ranked session? The Stream Dock battery plugin centralizes all your peripheral battery readouts in one clean dashboard, so you never get sidelined by a dead device mid-stream, game or work session.
Grab the Stream Dock Battery Plugin Here https://space.mirabox.net/product/20250730000814?lang=en
What Makes This Battery Tracker Stand Out From Default Tools
Built exclusively for the Stream Dock ecosystem, this lightweight plugin solves every common pain point that plagues multi-peripheral desktop setups:
Stream Dock N1
Full cross-brand gaming gear compatibility: It natively pulls accurate battery data from Logitech G HUB devices, Razer Synapse peripherals, and all Xbox wireless controllers — no need to keep those resource-heavy vendor apps running in the background 24/7.
Latest critical fixes & upgrades: The newest release fully resolves the long-standing Xbox controller battery detection bug, and adds brand new support for Xbox wireless headset battery monitoring, so your entire audio and control setup’s power status is visible at a glance.
Universal Bluetooth device coverage: Beyond branded gaming gear, the plugin now detects and displays battery levels for nearly all standard Bluetooth peripherals, from wireless mice and keyboards to styluses and portable speakers.
Redesigned, user-friendly UI: The updated interface uses high-contrast color coding, clear percentage labels and subtle low-power alerts, making it far easier to read than tiny, clunky system tray icons.
Expanded global support: Full Greek language localization is now included, delivering a seamless native experience for Greek-speaking users without any broken or untranslated UI elements.
No More Wasted RAM, No More Unexpected Disconnects
Most gamers run 2-3 separate vendor software suites just to track their device batteries, eating up 10%+ of their system RAM for no real benefit. This Stream Dock battery plugin uses less than 1% CPU in the background, updating all your device power levels every 30 seconds without dragging down your game performance.
You can set custom low-battery threshold alerts that pop up directly on your Stream Dock, so you can plug in your controller during a game loading screen instead of getting kicked from a competitive match with 0% battery. It’s the tiny quality-of-life upgrade that eliminates one of the most annoying, avoidable frustrations on any multi-peripheral desktop setup.
Install in 2 Minutes, Zero Complex Configuration
Head to the official product page to download the latest plugin build
Drop the plugin file into your Stream Dock plugins folder, it will auto-register on next launch
Drag the battery monitor widget to any empty slot on your Stream Dock layout — all your paired compatible devices will show up automatically in seconds
You can drag and drop to reorder devices, so your most-used controller or headset stays at the top of the dashboard for instant, one-glance power checks.
If you’re building out your perfect Stream Dock workflow, this battery plugin is one of the highest-utility, lowest-fuss additions you can add to your setup. It works seamlessly with all other Stream Dock productivity and streaming plugins, no conflicts or extra setup required.
