How to Use Operation Flow
Understanding Action Flow, Carousel, and Action Toggle on StreamDock
If you’re using a StreamDock, stream deck alternative, macro keyboard, or LCD control deck, you may have noticed a feature called Operation Flow.
For many beginners, it can feel confusing at first.
But once you understand how it works, Operation Flow becomes one of the most powerful tools for:
  • Workflow automation
  • Streaming setup
  • OBS control
  • Gaming shortcuts
  • Office workflow
  • AI productivity
  • Creator tools
This guide explains:
  • How Operation Flow works
  • What each mode does
  • When to use Action Flow, Carousel, or Action Toggle
  • How to build better productivity workflows
What Is Operation Flow?
Operation Flow allows a single button to execute multiple actions automatically.
Instead of triggering only one shortcut, one button can perform an entire workflow sequence.
Example:
Action A → Action B → Action C
This is especially useful for:
  • Streaming workflow
  • OBS plugin setups
  • Productivity workflow automation
  • Shortcut setup
  • Smart home control
  • Gaming setup
  • Creator AI workflows
If you use a wireless stream deck, wireless control deck, or keyboard with screen, this feature can significantly improve efficiency.
How Does Operation Flow Work?
1. Sequential Execution
All actions execute from top to bottom in order.
Example:
Open OBS
→ Launch Spotify
→ Open Browser
→ Switch Stream Scene
This creates a smooth automated workflow.
Perfect for:
  • Live streaming tools
  • OBS controller workflows
  • Automation tools
  • Office workflow setups
2. Delay Between Actions
You can add delays between actions.
Example:
Action A
→ Wait 500ms
→ Action B
Delays help prevent:
  • Missed shortcuts
  • Loading conflicts
  • Failed plugin actions
  • Timing issues
This is extremely useful for:
  • Streaming setup
  • Workflow tools
  • Gaming keyboard automation
  • AI productivity workflows
  • OBS control
3. Workflow Completion
After the final action runs, the Operation Flow ends automatically.
No extra interaction is needed.
What Actions Can Be Added?
Operation Flow supports many action types, including:
  • Hotkey
  • Super Hotkey
  • Keyboard shortcuts
  • Opening apps
  • Opening websites
  • Media controls
  • Plugins
  • Scripts
  • Device controls
  • Smart home automation
This flexibility makes it one of the most powerful workflow automation features available on a stream deck alternative or macro keyboard.
Real-World Use Cases
Gaming Setup
One button can execute a complete action combo.
Example:
Open Inventory
→ Equip Item
→ Activate Skill
→ Switch Mode
Perfect for:
  • Gaming keyboard workflows
  • Custom shortcuts
  • Shortcut setup
  • Creator tools
Smart Home Automation
Using a plugin, one button can:
  • Turn on lights
  • Start the AC
  • Power on entertainment devices
One button = one complete home scene.
Streaming Workflow
One button can:
Launch OBS
→ Open Twitch Dashboard
→ Start Spotify Playlist
Perfect for:
  • OBS plugin workflows
  • Twitch plugin setups
  • Streaming workflow automation
  • Creator productivity
Understanding the Three Modes
This is where most confusion happens.
Here’s the simple explanation.
1. Action Flow
Best For:
One-click workflow automation
Features
  • Executes all actions automatically
  • Supports delays
  • Runs from start to finish
Common Uses
  • Office workflow
  • Streaming setup
  • Smart home scenes
  • Automation tools
Recommended If:
You want:
“One button triggers everything automatically.”
2. Carousel
Best For:
Cycling through functions
Features
  • Each press switches to the next action
  • Button content changes dynamically
  • Saves button space
Example:
Press 1 → Tool A
Press 2 → Tool B
Press 3 → Tool C
Common Uses
  • Multi-function buttons
  • OBS scene switching
  • Streaming setup
  • Productivity tools
Recommended If:
You want:
“One button with multiple rotating functions.”
3. Action Toggle
Best For:
State switching
Features
  • Each press changes to the next state
  • No delays required
  • Better for controlled switching
Common Uses
  • Work / entertainment mode
  • Toggle actions
  • Device state control
  • Gaming setup switching
Recommended If:
You want:
“Press once for State A, press again for State B.”
Why Operation Flow Feels Powerful
Operation Flow is highly customizable.
That flexibility makes it extremely useful for:
  • Streaming setup
  • AI tools
  • Gaming keyboard control
  • OBS control
  • Creator AI shortcuts
Once you understand it, complex tasks become simple button presses.
Tips for Beginners
Start Simple
Begin with:
  • Fewer actions
  • One goal per workflow
  • Basic shortcut setup
Add Delays When Needed
If actions fail occasionally:
  • Add small delays
  • Test timing
  • Adjust gradually
Build Complexity Slowly
The best workflow automation setups are usually built step-by-step.
Operation Flow is designed to simplify complex workflows.
Whether you’re using:
  • A stream deck alternative
  • A wireless stream deck
  • A macro keyboard
  • A keyboard with screen
  • A creator control deck
Operation Flow can dramatically improve:
  • Productivity
  • Gaming setup
  • Office workflow
  • AI productivity
  • Creator tools
Experiment with different modes and build the workflow that fits your setup best.
