stream dock
How to Control Volume with Stream Dock
 Controlling your computer volume shouldn’t require constantly switching windows or reaching for the Windows volume panel. With MiraBox Stream Dock, you can assign volume controls directly to LCD keys or rotary knobs, giving you faster access to the audio settings you use every day.
Whether you're gaming, streaming, editing videos, listening to music, or working from home, Stream Dock makes volume control much easier.
What Can You Control with Stream Dock?
Depending on your Stream Dock device, you can use buttons or rotary knobs to control common audio actions such as:
  • Volume Up
  • Volume Down
  • Mute / Unmute
  • Media Play / Pause
  • Previous Track
  • Next Track
For Stream Dock models equipped with rotary knobs, volume adjustment feels especially natural: simply rotate the knob to increase or decrease the volume.
This lets you control audio without leaving your current application.
MiraBox  Stream Dock
Step 1: Connect Your Stream Dock
Connect your MiraBox Stream Dock to your computer using the supplied USB cable.
Then open the Stream Dock software.
Make sure your device appears in the device list and shows as connected before continuing.
Step 2: Select the Key or Knob You Want to Use
Choose your Stream Dock device inside the software.
You will see a preview of the buttons, LCD keys, touch controls, or rotary knobs available on your device.
Click the button or knob you want to use for volume control.
For devices with multiple knobs, you can dedicate one knob entirely to system volume while keeping the others available for application shortcuts or other controls.
Step 3: Add a Volume Control Action
From the function list, find the audio or multimedia control functions.
Select the volume function you want to assign.
For example:
Rotate Right: Volume Up
Rotate Left: Volume Down
Press Knob: Mute / Unmute
Once configured, the rotary knob becomes a dedicated physical volume controller for your computer.
If your Stream Dock model does not have rotary knobs, you can also assign Volume Up, Volume Down, and Mute to individual LCD keys.
Step 4: Test the Volume Control
After assigning the actions, rotate the knob or press the configured buttons.
Your computer volume should respond immediately.
Try opening a video, music application, game, or other audio source to confirm that the controls work as expected.
You can return to the Stream Dock software at any time to change the functions or rearrange your layout.
A Simple Volume Control Layout
One useful setup is:
Control Function
Rotate Left Volume Down
Rotate Right Volume Up
Press Knob Mute / Unmute
LCD Key 1 Play / Pause
LCD Key 2 Previous Track
LCD Key 3 Next Track
With this setup, most everyday media controls can be handled directly from your desk.
Why Use Stream Dock for Volume Control?
Keyboard media shortcuts work, but they are not always convenient—especially when you are working inside a full-screen application.
A dedicated Stream Dock gives you physical controls that remain available regardless of what is currently on screen.
For example, you can adjust the volume while:
  • Playing a game
  • Editing a video
  • Streaming with OBS
  • Joining an online meeting
  • Listening to Spotify or other music apps
  • Working in Photoshop, Premiere Pro, or other creative software
Instead of interrupting your workflow, you simply turn a knob or press a button.
Build Your Own Desktop Control Setup
Volume control is only one of the functions available in Stream Dock.
You can also configure Stream Dock to:
  • Launch applications
  • Open websites
  • Trigger keyboard shortcuts
  • Control music
  • Run macros
  • Switch pages and scenes
  • Execute custom workflows
  • Use community plugins and profiles
This makes Stream Dock more than a simple shortcut pad—it can become a central controller for your desktop workflow.
Explore the MiraBox Stream Dock series to find a model that fits your setup:
https://www.mirabox.net/collections/stream-dock
You can also discover more plugins, workflows, device setups, and community-created ideas through the MiraBox ecosystem.
Can Stream Dock control Windows system volume?
Yes. You can assign volume up, volume down, and mute functions to compatible Stream Dock buttons or rotary knobs.
Can I use a knob to control volume?
Yes. Stream Dock models with rotary knobs are especially suitable for volume control. You can typically configure clockwise rotation for volume up, counterclockwise rotation for volume down, and knob press for mute.
Can I control music with Stream Dock?
Yes. In addition to volume control, you can configure common media functions such as play/pause, previous track, and next track.
Do I need to keep the Stream Dock software open?
The exact behavior depends on the device, function, plugin, and configuration being used. For software-based integrations, keeping Stream Dock running in the background is recommended.
Conclusion
Using Stream Dock to control volume gives you a faster and more convenient way to manage computer audio.
Assign volume up, volume down, and mute to a rotary knob or LCD keys, and you can adjust your audio without interrupting what you're doing.
For gaming, streaming, creative work, or everyday desktop use, it is a small change that can make your setup feel much more efficient.
