Soundboard Dock Setup: How to Use SoundPad with Stream Dock
A soundboard dock is a physical control surface for triggering configured sounds without returning to the sound application. With a compatible MiraBox Stream Dock and its SoundPad integration, start with a small set of clips, then test the actual audio path in your intended call or recording application.
  • Test each clip inside SoundPad before assigning a hardware key.
  • Keep SoundPad running and check the current SPACE requirements for your installed plugin.
  • Use recognizable labels and confirm the other participant or recording receives the expected sound.
If you use SoundPad for gaming, Discord, voice chat, or streaming, switching back to the app every time you want to play a sound can quickly become annoying.
With the SoundPad plugin for MiraBox Stream Dock, you can turn the LCD keys on your controller into physical soundboard buttons. Press a key, trigger a sound, and keep your focus on the game or conversation.
SoundPad is designed to play sounds and music through your microphone signal, making it useful for voice chats and gaming. A controller integration also means you do not have to rely on a large collection of keyboard hotkeys.
MiraBox N4
What You Need
Before starting, make sure you have:
  • A compatible MiraBox Stream Dock
  • Stream Dock software installed
  • SoundPad installed on your Windows PC
  • Several sounds already added to your SoundPad library
  • The SoundPad plugin from MiraBox Space
You can find the SoundPad plugin in MiraBox Space and install it directly for use with Stream Dock.
Plugin: SoundPad
Download: MiraBox Space SoundPad Plugin
SoundPad plugin listing and requirements
Step 1: Set Up SoundPad
Open SoundPad first and add the audio clips you want to use.
These could be meme sounds, game effects, notification sounds, short music clips, or audio you regularly use during Discord calls and streams.
Test the sounds inside SoundPad before continuing so you know they are playing correctly.
Step 2: Install the SoundPad Plugin
Open the Stream Dock software and go to Space.
Search for:
SoundPad
Download and install the plugin. After installation, SoundPad actions should appear in the Stream Dock action panel.
MiraBox also provides its own SoundPad integration for Stream Dock users.
MiraBox M3 Control Soundpad
Step 3: Assign a Sound to an LCD Key
Select an empty LCD key on your Stream Dock.
Drag the SoundPad action onto the key and configure the sound you want the button to trigger.
Repeat the process for your most-used sounds.
For example:
Key 1: Applause
Key 2: Laugh
Key 3: Game sound effect
Key 4: Notification
Key 5: Meme sound
Key 6: Stop playback, if the installed integration exposes that action
You can also customize the key icon so each sound is easy to recognize at a glance.
Step 4: Try Your New Soundboard
Keep SoundPad running and press one of the configured Stream Dock keys.
Instead of switching windows or remembering keyboard shortcuts, you can now trigger your sounds directly from the hardware.
This is especially convenient when you are gaming, talking with friends on Discord, streaming, or recording content.
Why Use SoundPad with Stream Dock?
The biggest advantage is simple: faster access.
Your favorite sounds are always visible on physical LCD keys, and you can organize different sounds across multiple Stream Dock pages.
For users looking for a Stream Deck alternative for SoundPad, MiraBox Stream Dock provides another way to build a customizable physical soundboard while keeping your existing SoundPad workflow.
Turn a few LCD keys into a soundboard, press the button, and let Stream Dock handle the rest.
Check the audio path before using it live
Use MiraBox Download for current software and the model guide if you are choosing hardware. First record or privately test a single clip. If you can hear it but the other participant cannot, check the selected input and output in SoundPad and the destination app before changing the button assignment. Do not assume every voice or streaming app uses the same audio route.
Do I need SoundPad installed to use this setup?
Yes. This tutorial uses SoundPad and its MiraBox integration; check the current plugin listing for the applicable environment and requirements.
Can any Stream Deck plugin be used on this dock?
Do not assume that. Use the MiraBox SPACE integration specified for your Stream Dock software and device.
Why can I hear a clip but others cannot?
Check the microphone and audio routing in the intended application. Confirm the route with a private call or recording before going live.
