Find and Install Stream Dock Resources from Store and Space
Stream Dock provides different resources to help you customize your device, including icons, scenes, animated backgrounds, and plugins.
These resources are also part of the MiraBox Ecosystem, helping users find ready-made tools, layouts, and visual assets for different Stream Dock workflows.
Icons can make your keys easier to recognize. Scenes can help you apply a complete layout quickly. Animated backgrounds can make supported devices more visual. Plugins can add more functions to your Stream Dock software.
You can get these resources from the built-in Store or from MiraBox Space.
What Resources Are Available?
You can find several types of resources for Stream Dock:
  • Icons
  • Scenes
  • Animated backgrounds
  • Plugins
  • Tutorials
  • Other related resources
Different resource types are used for different purposes.
For example, icons are used to customize key images, scenes are used to import complete layouts, and plugins are used to add extra functions.
Method 1: Get Resources from the Built-in Store
Open the Stream Dock software.
Click the Store icon in the upper-left corner.
In the Store, you can browse different categories, such as:
  • Plugins
  • Icons
  • Scenes
  • Tutorial
Choose the resource you want to use, then click Install.
After installation, the resource will be available in Stream Dock software.
Method 2: Get Resources from MiraBox Space
You can also get resources from MiraBox Space.
Click the Space icon in the Stream Dock software, or visit MiraBox Space in your browser.
In MiraBox Space, you can browse categories such as:
  • Plugins
  • Icons
  • Scenes
  • Numeric Keycap
You can use the search bar to find a specific resource, open the resource page, and follow the instructions to download or use it.
Important Notes
Before using a resource, check whether it supports your device and software version.
Scenes need to match the corresponding device model. A scene created for one Stream Dock model may not appear or work correctly on another model.
Plugins are not limited by device model. You can use plugins across different Stream Dock devices.
Animated backgrounds are currently supported only on:
  • N4 Pro
  • M3
  • XL
If your device does not support animated backgrounds, this type of resource may not work on your device.
Best Use Cases
These resources can be helpful when you want to:
  • Customize key icons
  • Use a ready-made scene layout
  • Add animated visuals to supported devices
  • Install plugins for extra functions
  • Save setup time
  • Try layouts shared by other users
Using the Store and MiraBox Space can make it easier to build a Stream Dock setup that fits your daily workflow.
The built-in Store and MiraBox Space are the main places to get Stream Dock resources in the MiraBox Ecosystem.
Use the Store when you want to install resources directly in the software. Use MiraBox Space when you want to explore more resources online.
Before using scenes or animated backgrounds, remember to check device compatibility.
