Configure RGB Lighting on Stream Dock
Some Stream Dock devices support RGB lighting settings. You can adjust the light color, brightness, lighting mode, and sleep follow behavior in the Stream Dock software.
This guide explains how to set device RGB and which models currently support this function.
Supported Device Models
Device RGB settings are currently supported on the following models:
  • M18V3
  • N4 Pro
  • XL
  • Mini
  • MiniW
The available settings may be slightly different depending on the device model.
What Can You Set?
Depending on your device, you can adjust:
  • RGB color
  • Light brightness
  • Lighting control mode
  • LED sleep follow setting
  • Restore default lighting settings
These options allow you to customize the lighting style of your Stream Dock device.
How to Set RGB Color
Select the device you want to adjust in the Stream Dock software.
Then select the button or lighting area that supports RGB settings.
In the settings panel, find RGB and click the color block.
Choose the color you want to use.
After selecting a color, the device lighting will update based on your setting.
How to Adjust Light Brightness
Open the StreamDock software.
Click the Setting icon.
Go to:
Device > Light Brightness
Drag the slider to adjust the light brightness.
Move the slider to the right to increase brightness. Move it to the left to lower brightness.
How to Set Lighting Control
In the Device tab, find Lighting control.
You can select the lighting mode from the dropdown menu.
Available options may include:
  • Light
  • Follow the software
If you choose Light, the device will use the lighting setting directly.
If you choose Follow the software, the device lighting will follow the software setting.
How to Restore Default RGB Settings
If you want to reset the lighting settings, click Restore Default.
This will restore the RGB or lighting settings to the default state.
Use this option if the lighting color or brightness is not what you expected.
Important Notes
RGB options may look different on different Stream Dock models.
For example, N4 Pro may show Light Brightness and Lighting control, while M18V3 may show Led, RGB, Reset RGB, and LED Sleep Follow.
If you cannot find a specific RGB option, please check whether your device model supports that setting.
Device RGB settings allow you to customize the lighting effect of your Stream Dock. You can set the RGB color, adjust brightness, select lighting control mode, and enable LED sleep follow when supported.
These settings can help your StreamDock better match your desk setup and daily workflow.
