How to Use the Audio Player Feature on StreamDock
Play Audio, Stop Audio, and Control Playback Devices
The Audio Player feature allows StreamDock devices to quickly play or stop audio files with a single button press.
This feature is useful for:
  • Streaming setup
  • OBS workflows
  • Soundboard effects
  • Gaming setup
  • Creator tools
  • Productivity workflows
  • Live streaming tools
It supports both:
  • Play Audio
  • Stop Audio
functions for fast and flexible audio control.
Play Audio Function
What Does It Do?
The Play Audio function allows you to select and play a local audio file directly from StreamDock.
This is perfect for:
  • Sound effects
  • Background music
  • Stream alerts
  • Voice clips
  • Creator workflows
  • Gaming audio triggers
Supported Audio Formats
The Audio Player currently supports:
  • mp3
  • wav
  • mp4
  • m4a
  • m4b
  • m4p
  • mov
  • aiff
  • flac
This allows compatibility with most commonly used audio and media formats.
How to Set Up Play Audio
Step 1
Drag the:
Play Audio
action into the key configuration area.
Step 2
Click the Select button on the right-side property panel.
Then choose the audio file you want to use.
Playback Options
The Audio Player feature supports several playback controls.
1. Playback Command Selection
You can freely choose how the audio command behaves depending on your workflow setup.
2. Volume Control
You can choose the playback volume for each audio action individually.
This is useful when balancing:
  • Background music
  • Alerts
  • Notifications
  • Voice clips
  • Stream effects
3. Output Device Selection
You can choose which audio device the sound plays through.
Examples include:
  • Speakers
  • Headphones
  • Streaming mixer devices
  • Virtual audio devices
Perfect for:
  • OBS control
  • Live streaming setup
  • Dual-PC streaming workflows
  • Creator workstations
Stop Audio Function
What Does It Do?
If you want to stop the currently playing audio immediately:
Simply press:
Stop Audio
The playback will stop instantly.
