Stream Dock Core Features Overview
Folders, Scene Switching, Page Navigation, Brightness Control & Sleep Functions
StreamDock devices are designed to improve workflow automation, streaming setup efficiency, gaming setup customization, and creator productivity.
This guide introduces several core Stream Dock features that help users organize pages, switch scenes, control device behavior, and build more efficient creator workflows.
Perfect for users of:
  • Stream Dock devices
  • Stream deck alternatives
  • Macro keyboards
  • LCD control decks
  • Creator workflow setups
  • Wireless control decks
1. Create Folder
What Does Create Folder Do?
Create Folder allows you to organize actions, plugins, shortcuts, and workflows inside a dedicated folder.
This helps maximize limited key space while keeping layouts clean and easy to navigate.
Features
  • Store more actions inside one key
  • Support folder nesting
  • Better workflow organization
  • Cleaner streaming and productivity layouts
Current limitation:
  • Each folder currently supports one page of content
Best Use Cases
Perfect for:
  • Workflow automation
  • Streaming workflow organization
  • OBS control layouts
  • Productivity workflow setups
  • Gaming setup shortcuts
  • Creator tools
2. Scene Shift
What Is Scene Shift?
Scene Shift allows fast switching between different scenes and pages.
You can directly jump to:
  • A specific device
  • A specific scene
  • A specific page
Simply drag the action into the key area and press the assigned key to switch instantly.
Best Use Cases
Perfect for:
  • OBS control
  • Streaming setup
  • Multi-device creator workflows
  • Gaming profiles
  • Productivity workflows
  • AI productivity setups
3. Previous Page & Next Page
What Do These Actions Do?
These actions allow quick navigation between pages inside the same scene.
Functions include:
  • Previous Page
  • Next Page
This is especially useful when managing large workflow layouts or multi-page shortcut systems.
Best Use Cases
Useful for:
  • Macro keyboard workflows
  • LCD control deck navigation
  • Streaming workflow pages
  • Gaming setup pages
  • Creator tools
4. Go to Page
What Does Go to Page Do?
Go to Page allows you to jump directly to a specific page inside the current scene.
Unlike Previous/Next Page, this action immediately opens the target page without cycling through pages one by one.
Best Use Cases
Perfect for:
  • Fast creator workflow navigation
  • OBS control pages
  • Productivity tools
  • Streaming setup shortcuts
5. Page Indicator
What Is Page Indicator?
Page Indicator displays the current page number directly on the device.
This helps users:
  • Understand current page position
  • Navigate large layouts more easily
  • Improve workflow visibility
Best Use Cases
Especially useful for:
  • Stream deck alternative setups
  • LCD control deck layouts
  • Multi-page creator workstations
6. Brightness
What Does Brightness Control Do?
Brightness allows users to adjust device display brightness directly from a key.
Functions include:
  • Brightness Increase
  • Brightness Decrease
Brightness settings can be customized inside the plugin property panel.
After pressing the assigned key:
  • The screen becomes brighter
  • Or dimmer depending on the selected action
Best Use Cases
Perfect for:
  • Streaming environments
  • Gaming setup customization
  • Night-time workflows
  • Creator workstations
  • Office productivity
7. DevSleep
What Is DevSleep?
DevSleep allows the device to enter sleep mode manually.
After activation:
  • The screen turns off
  • The device enters low-power standby mode
To wake the device:
  • Press any key
The device will automatically resume normal operation.
Best Use Cases
Useful for:
  • Energy saving
  • Desk idle states
  • Streaming setup environments
  • Creator workflows
  • Productivity workstations
Why These Features Matter
These core StreamDock features help users build more organized and efficient setups for:
  • OBS control
  • Gaming setup
  • AI productivity
  • Creator tools
Whether you are using:
  • A stream deck alternative
  • A wireless stream deck
  • A macro keyboard
  • A keyboard with screen
  • An LCD control deck
these features help improve both usability and workflow efficiency.
