MagTran M3 Beginner Guide
Beginner Quick Start Guide for Magnetic Keys, Dynamic Backgrounds, and Interactive Features
The MagTran M3 is not just another stream deck alternative or macro keyboard.
It introduces:
  • Magnetic trigger technology
  • Interactive backgrounds
  • Dynamic screen savers
  • Per-key visual effects
  • Mini games
  • Advanced creator workflows
This beginner guide focuses specifically on the unique features of the MagTran M3 and explains how to get started quickly.
Based on the original tutorial document
What Makes MagTran M3 Different?
Unlike traditional stream deck devices or LCD control decks, the MagTran M3 uses a magnetic trigger system instead of conductive membrane detection.
This allows:
  • More consistent key triggering
  • Advanced visual effects
  • Better long-term durability
  • Enhanced creator experiences
Perfect for:
  • Streaming setup
  • Gaming setup
  • Workflow automation
  • OBS control
  • AI productivity
  • Creator tools
How the M3 Magnetic Keys Work
Magnetic Trigger Mechanism
The entire key area operates inside a stable magnetic field.
Each LCD key contains a built-in miniature magnet.
When a key is pressed:
Magnetic field changes
→ System detects movement
→ Key press is identified
→ Action is executed
This design offers several advantages:
  • No physical contact wear
  • Higher trigger consistency
  • More advanced interaction effects
  • Better visual feedback support
When Should You Perform Magnetic Calibration?
Magnetic calibration may be needed if:
  • The device experienced strong magnetic interference during shipping
  • Magnetic objects are near your desk
  • Keys stop responding
  • Incorrect keys trigger unexpectedly
This is completely normal for magnetic-trigger devices.
How to Perform Magnetic Calibration
Step 1
Open the software and click:
The device will enter calibration mode.
Step 2
The 15 LCD keys will light up blue one by one.
When a key changes:
Blue → Red
Press and hold that key for about 3 seconds.
Step 3
After successful calibration:
Red → Green
Repeat the process for all keys.
Calibration Tips
For best results:
  • Do not tap quickly
  • Release only after the color changes
  • Avoid interruptions during calibration
If calibration fails:
  1. Disconnect the device
  2. Reconnect it
  3. Restart calibration
How to Use Key Effects
What Are Key Effects?
Key Effects are animated visual effects that play when a key is pressed.
This creates a more immersive creator and gaming setup experience.
Perfect for:
  • Streaming workflow
  • Gaming keyboard setups
  • Creator tools
  • Interactive workflows
How to Configure Key Effects
Steps
  1. Right-click any key
  2. Open:
Key Effect Library
  1. Select an effect
You can:
  • Assign unique effects to each key
  • Enable random effects
  • Mix multiple effects on the same page
How to Disable Key Effects
Simply reset the effect for that specific key.
Each key works independently.
What Are Interactive Backgrounds?
Interactive Backgrounds are a new background category exclusive to M3.
Unlike normal wallpapers:
  • They are rendered in real time
  • Plugins control the visuals
  • Backgrounds react to user interaction
This creates a much more immersive setup for:
  • Streaming setup
  • Gaming setup
  • Creator AI workflows
  • OBS control environments
Dynamic Screen Saver Plugin Guide
What Does It Do?
The Dynamic Screen Saver plugin enhances the idle display experience.
Instead of simply switching between:
  • Black screen
  • Static wallpaper
the M3 can display:
  • Animated information panels
  • Dynamic clocks
  • Notes
  • Interactive visual effects
How to Enter Screen Saver Mode
Automatic Activation
The screen saver can activate:
  • After a timer
  • At scheduled times
Manual Activation
You can also assign a key to trigger the screen saver directly.
What Happens During Sleep?
When the device or computer sleeps:
  1. The screen first turns black
  2. Pressing a key again:
    • Wakes the device
    • Displays the screen saver
This is normal behavior.
Two Screen Saver Modes
Mode 1 — Information Dashboard (Recommended)
Includes:
  • Digital clock
  • Notes panel
  • Time gradient lighting
  • Calendar
The Notes section syncs with the Notes plugin.
You can customize:
  • Font size
  • Position
  • Layout
Perfect for:
  • Productivity workflow
  • Office workflow
  • Creator workstations
Mode 2 — Minimal Mode
Includes:
  • Digital clock
  • Custom background image
You can customize:
  • Clock colors
  • Wallpapers
  • Background images
Perfect for:
  • Minimal streaming setups
  • Gaming desk aesthetics
  • Creator setups
Important Screen Saver Notes
Make sure you are currently on the:
Screen Saver Settings Page
Otherwise, the device will only switch between:
  • Screen off
  • Default wallpaper
Also:
  • Only one screen saver can be active at a time
  • Multiple screen savers on different pages are not supported
This prevents plugin conflicts.
Coin Eater Mini Game
What Is Coin Eater?
Coin Eater is a built-in mini game for casual entertainment.
How to Play
Controls
Press the Coin Key to:
  • Enter the game
  • Exit the game
During gameplay:
  • Press any key except Exit
  • Jump
  • Double jump
  • Collect coins
Leaderboard Support
After the game ends, scores are automatically recorded.
You can view:
  • Personal rankings
  • Global rankings
inside the plugin property panel.
Time Gradient Background (Experimental)
What Is It?
Time Gradient automatically changes background filters based on system time.
Current states include:
  • Morning
  • Dusk
  • Night
Recommended Usage
For best visual quality:
  • Use light-colored static wallpapers
  • Avoid extremely dark backgrounds
The MagTran M3 is designed to go beyond traditional stream deck alternatives.
With features like:
  • Magnetic trigger keys
  • Per-key effects
  • Creator AI integrations
it offers a much more immersive experience for:
  • Streaming setup
  • Gaming setup
  • OBS control
  • Creator tools
  • AI productivity
Once you get familiar with the M3 ecosystem, it becomes an incredibly flexible creator control platform.
