Control Microsoft Flight Simulator with StreamDock and AAO
Build a Custom Flight Simulator Control Deck for MSFS
As Microsoft Flight Simulator becomes more advanced and realistic, many sim pilots are looking for better ways to control aircraft systems efficiently.
Using a StreamDock, stream deck alternative, or macro keyboard together with AAO (AxisAndOhs) allows you to build a highly customizable flight simulator control setup for MSFS.
This guide explains:
  • What StreamDock + AAO can do
  • Required hardware and software
  • How to install AAO
  • How to connect everything
  • Real-world cockpit workflow examples
  • Common troubleshooting tips
Based on the original tutorial document
What Can StreamDock + AAO Do?
With StreamDock and AAO, you can control aircraft systems directly from your LCD control deck or creator workflow setup.
Examples include:
  • Landing gear
  • Aircraft lights
  • Autopilot controls
  • Flaps
  • NAV systems
  • Heading adjustments
  • Altitude controls
  • Engine systems
You can also use encoder knobs for precise adjustments such as:
  • Heading
  • Altitude
  • Trim
  • Throttle
  • Radio frequencies
This creates a much more immersive flight simulator workflow compared to using only a mouse and keyboard.
System Architecture
The typical setup flow looks like this:
StreamDock Device
→ Install VSD Craft
→ Install AAO
→ Install AAO Plugin
→ Connect to Microsoft Flight Simulator
Requirements
Hardware
You will need:
  • StreamDock device
  • Windows PC
Software
Required software includes:
  • VSD Craft
  • Microsoft Flight Simulator
  • AAO (AxisAndOhs)
  • AxisAndOhs StreamDock Plugin
AAO is currently one of the most reliable and mature control bridge tools available for MSFS.
It supports:
  • Advanced aircraft systems
  • Third-party aircraft
  • SimVars
  • LVars
  • HVars
Perfect for serious flight simulator setups.
How to Install AAO
Step 1 — Install AxisAndOhs
Download AAO from the official website:
AxisAndOhs Downloads
After installation:
  • Make sure AAO matches your MSFS version
  • Launch Microsoft Flight Simulator at least once
Step 2 — Install the StreamDock Plugin
Download the AAO plugin from:
Important:
Use:
Plugin for the Mirabox StreamDock
Do NOT use the original Elgato Stream Deck AAO plugin.
How to Configure StreamDock with AAO
Step 1 — Create an Action
Inside StreamDock:
  1. Create a button or encoder
  2. Select:
AAO / External Interface
  1. Bind the desired AAO action or script
Step 2 — Configure Input Types
You can configure:
  • Single press
  • Long press
  • Encoder rotation
  • Clockwise rotation
  • Counter-clockwise rotation
This makes StreamDock perfect for:
  • Flight simulator workflow automation
  • Creator tools
  • Gaming setup customization
  • Advanced cockpit control systems
Typical Flight Simulator Pages
Ground Operations Page
Recommended controls:
  • Engine start
  • Taxi lights
  • Takeoff lights
  • Flaps
Cruise Page
  • Autopilot
  • Heading
  • Altitude
  • NAV modes
  • APPR modes
Perfect for:
  • Workflow automation
  • Encoder knob usage
  • Professional cockpit layouts
Landing Page
  • Landing gear
  • Spoilers
  • Autobrake
  • Final approach controls
Recommended Advice for Beginners
For new users, manually configuring AAO scenes and scripts can feel overwhelming.
A better starting point is downloading community-made layouts from Flightsim.to.
These prebuilt scenes help you:
  • Learn workflow structure
  • Understand AAO bindings
  • Build profiles faster
  • Improve your cockpit setup
Recommended Creator
One highly recommended creator is:
Guenseli on Flightsim.to
Please respect the original creators.
Avoid modifying or redistributing their work commercially without permission.
Troubleshooting Tips
StreamDock Actions Don’t Respond
Check:
  • MSFS is already in-flight
  • AAO connection status
  • Plugin version compatibility
  • Firewall settings
  • SimConnect connection
Encoder Knobs Don’t Rotate Properly
Make sure:
  • Encoder assignments are configured in AAO
  • Clockwise / counter-clockwise actions are set correctly in VSD Craft
Should Different Aircraft Use Different Profiles?
Yes.
This is strongly recommended for aircraft like:
  • A32NX
  • PMDG
  • Fenix
Different aircraft often use different variable systems and workflows.
Why This Setup Is So Powerful
Using StreamDock with AAO allows you to create a professional flight simulator control deck with:
  • LCD control interfaces
  • Encoder controls
  • Custom cockpit pages
  • Stream deck alternative flexibility
  • Advanced simulator integration
This setup greatly improves:
  • Flight immersion
  • Workflow speed
  • Cockpit organization
  • Simulator interaction efficiency
The combination of:
  • StreamDock
  • AAO
creates a highly scalable and professional flight simulator workflow system.
Whether you are using:
  • A stream deck alternative
  • A macro keyboard
  • A wireless control deck
  • A creator control setup
this workflow can dramatically improve your MSFS experience.
