MiraBox Space Resource Center Guide: Find, Download, and Use Resources for MiraBox Products
MiraBox Space is the central resource platform for the MiraBox Ecosystem. It provides plugins, icons, scenes, animated backgrounds, numeric keycap skins, themes, tutorials, and other downloadable content for different MiraBox product lines.
Whether you use a Stream Dock controller, smart display, keyboard, SyncRGB lighting device, or another MiraBox product, you can select your product series and device model to find compatible resources.
The available content and installation process may vary by product. To make the workflow easier to understand, this guide uses Stream Dock as an example. Other MiraBox products follow a similar process, but their resource locations and settings may be different.
Ways to Enter MiraBox Space
There are three common ways to access MiraBox Space.
Use a Preset Resource Shortcut
Some MiraBox products include preset tutorial scenes or pages with shortcuts to plugins, icons, scenes, animated backgrounds, and other resources.
Press the corresponding key to open the resource page directly.
This is convenient for first-time users because you do not need to browse through each website category manually.
Open Space from MiraBox Software
Some MiraBox applications include a direct link to Space. For example, Stream Dock users can click the MiraBox Space icon at the top of the software.
The resource center will open in your default browser.
The location of this shortcut may vary between different MiraBox applications.
Visit the Website Directly
You can also visit MiraBox Space in your browser:
https://space.mirabox.net
Consider bookmarking the website so you can quickly return when you need new resources or updates.
Sign In to Your Account
After opening MiraBox Space, click Log In in the upper-right corner and follow the on-screen instructions.
If you are already signed in through the current browser, you can skip this step.
Signing in allows you to get resources and access content associated with your account. Some resources may require an account before they can be downloaded.
Select a Product Series and Device Model
Before downloading anything, choose your product series from the left sidebar. Available categories may include:
  • Stream Dock
  • Smart Screen
  • Keyboard
  • SyncRGB
Next, select your specific device model.
This step matters because MiraBox products may use different screen sizes, key layouts, knobs, touch controls, operating systems, and hardware functions. As a result, compatible resources can vary between models.
Selecting the correct product and model allows MiraBox Space to show more relevant content and reduces the chance of downloading an incompatible resource.
If a downloaded resource does not appear in the software, check that:
  1. You selected the correct product series.
  2. You selected the correct device model.
  3. The resource supports your operating system.
  4. Your MiraBox software meets the version requirements.
Resources Available in MiraBox Space
The available categories depend on the selected product and model.
Plugins
Plugins add new functions to compatible MiraBox products. They may provide application controls, system information, audio controls, productivity tools, streaming features, or content-creation shortcuts.
Some plugins require another application to be installed on your computer. They may also have operating-system or software-version requirements.
Icons
Icon packs change the appearance of keys and function modules. They can make controls easier to identify while giving your setup a consistent visual style.
Different icon packs may be designed for office work, streaming, gaming, design software, media control, or system shortcuts.
Scenes
A scene can contain a preconfigured collection of actions, icons, pages, and layouts. It allows you to load a complete workflow without configuring every control individually.
Scenes are often device-specific, so confirm that the scene supports your model before downloading it.
Animated Backgrounds
Animated backgrounds add motion to supported screens and display areas.
Not every device or interface area supports animated backgrounds. Check the resource details and device compatibility before downloading.
Numeric Keycap Skins, Themes, and More
Some keyboards and numeric keypads support downloadable keycap skins, themes, and other device-specific visual resources.
These resources may require a particular product model and may appear in a different part of the accompanying software.
Find the Resources You Need
After selecting your product and device, you can use search, filters, and sorting options to find suitable content.
Search by Name or Function
If you already know the resource name, enter it in the search bar.
You can also search by application name, function, icon style, or intended use.
Apply Filters
When a category contains many resources, use the available filters to narrow the results. Depending on the product, filters may include:
  • Resource type
  • Free or paid
  • Supported operating system
  • Supported device model
  • Function or use case
The available filters may vary between product categories.
Change the Sorting Order
You can also sort resources by options such as:
  • Most popular
  • Newest
  • Name
Combining search, filters, and sorting is usually the fastest way to find a suitable resource.
Check the Resource Details
Click a resource card to open its details page.
Before selecting Get, check:
  • What the resource does
  • Supported product series and device models
  • Supported operating systems
  • MiraBox software version requirements
  • Required third-party applications
  • Additional setup instructions
A resource may download successfully but still fail to appear or operate if the selected device, operating system, or software version is incompatible.
Stream Dock Plugin Download Example
Resource installation can vary by product. The following example shows the complete process for downloading a Stream Dock plugin.
Step 1: Open the Plugin Category
In MiraBox Space, select the Stream Dock product series and your device model. Then open the Plugins category.
Step 2: Find a Plugin
Search for the plugin by name or narrow the results using the available filters.
Click the plugin card to open its details page.
Step 3: Confirm Compatibility
Review the plugin description, supported systems, compatible devices, and software requirements.
Application-control plugins may require the corresponding program to be installed on your computer.
Step 4: Select Get
After confirming compatibility, click Get on the resource page.
Your browser may ask for permission to open Stream Dock. Select Open Stream Dock to continue.
Step 5: Wait for Installation
Stream Dock will open and display the download task and progress near the top of the software.
Wait until the installation confirmation appears.
Step 6: Add the Plugin Function
Installed plugins appear in the function library on the right side of Stream Dock.
Expand the plugin category, then drag the required function onto a key, knob, or supported touch area. Complete any additional settings shown in the property panel.
Where to Find Downloaded Stream Dock Plugins
Installed plugins usually appear in the right-side function library.
If you cannot find a plugin:
  1. Scroll through the function list.
  2. Expand the relevant plugin category.
  3. Search for the plugin name.
  4. Confirm that the download has finished.
  5. Restart Stream Dock.
Where to Find Downloaded Stream Dock Icons
Downloaded icons do not appear in the plugin list. They are stored in the Stream Dock Icon Library.
To apply an icon:
  1. Select the key you want to customize.
  2. Find the icon preview in the property panel.
  3. Right-click the icon.
  4. Select Open Icon Library.
  5. Expand the downloaded icon pack.
  6. Select an icon to apply it.
If an icon pack has been downloaded successfully, look for it in the Icon Library rather than the plugin panel.
Where to Find Stream Dock Animated Backgrounds
After getting an animated background from Space:
  1. Return to Stream Dock.
  2. Select a supported key or display area.
  3. Right-click the device canvas.
  4. Select Background Library.
  5. Find and apply the downloaded background.
If Background Library does not appear, the selected device or interface area may not support animated backgrounds.
Using Resources with Other MiraBox Products
Resources for other MiraBox products may appear in different locations.
For example, smart-display content may be applied through the relevant display software. Keyboard resources may appear under keycap or theme settings, while SyncRGB content may need to be configured through its lighting controls.
When downloading a resource for a product other than Stream Dock, check:
  • Instructions on the resource details page
  • The accompanying software for your product
  • The relevant theme, function, or resource-management page
  • Official MiraBox tutorials
Not finding a resource immediately does not always mean the download failed. First confirm that you are using the correct software, device model, account, and resource section.
Troubleshooting Missing Resources
If a downloaded resource does not appear, check the following:
  1. Make sure you are signed in with the account used to get the resource.
  2. Verify the selected product series and device model.
  3. Confirm that the resource supports your operating system.
  4. Check whether the download task has finished.
  5. Look in the correct plugin, icon, background, scene, or theme library.
  6. Restart the relevant MiraBox software.
  7. Review the resource page for additional installation requirements.
If the issue continues, contact MiraBox support or ask the community for help. Include your device model, software version, resource name, and screenshots of the issue.
Final Overview
Using MiraBox Space comes down to four steps:
  1. Select the correct product series and device model.
  2. Search or filter for the resource you need.
  3. Check compatibility and select Get.
  4. Open the corresponding MiraBox software or resource library to use it.
MiraBox Space is not limited to Stream Dock. It is a shared resource center supporting multiple product lines across the MiraBox Ecosystem. Stream Dock is used in this guide only as a clear example of the download and installation process.
With Space, you can add functions, customize device visuals, load prepared workflows, and discover new ways to use your MiraBox products.
